Home Made Frame Connectors
srduster340
Decatur,Ga.
For those of you who've made your own frame connectors, what size square tubing, including thickness, do I need?
I used 2X3X1/8 box tubing. Here's a sketch of what I did on our Valiant. Hope it helps.
bigblockdart.com used to have a great tech article...but they redid the website...
2x2 .120 on one end make a notch in each corner so all for sides can fold out about an 1in. then make a pie slice on the other end at the right length...
I used 2X3 and they are similar to Bigslim's, but mine were a bit simpler, I just cut the top section out at the rear to slide it over the rear rail. I also notched the sides so I could bend them to the angle to fit snugly on the rear and then welded up the notches.
same as blue missle, 1.5 x 3, .125 thick and if I remember correctly they are 43" long. Welded in of course. I made 3 pairs, one for me and two to sell.
