No idea. Here's what I'd try. Unplug the relay. Hook a test lamp to the black wire at the connector. Hook the other end of the test lamp to a "hot" battery source.
The lamp should light when you work the horn button, either key on or off.
Might be the column is not grounded, but that's only a wild guess
Any wiring mods you know of?
Any harness "meltage" from other damage / shorts you know of?
Is the wiring factory?
