It's not rpm that matters but hp, a stock 318 grosse under well under 200 hp and even less at 6000 rpm where as a 400 hp 318 (which will be peaking around there) will be moving a lot more air. There's a dyno of 318/360/340/5.9 manifolds on a 300 hp 360 and there's like 5 hp from worst to best even shorties only did a little better. The tube length is what makes headers work. So the more hp you build the more restrictive the manifolds become. If you want say 400 hp you'll probably need to build 440 - 450 hp engine and let your manifolds eat 40-50 hp.
