Not sure if this is correct, found it on google
From the Hurst site:
"OEM shifters used a "bayonet-style" stick, held in with two metal clips and rubber isolators on each side of the stick. To remove the stick, place or push a steel shim or feeler gauge down each side of the stick, at the bottom where the chrome handle goes into the mechanism, and pull. Should you need new clips and isolators, they are available through your nearest Hurst retailer or through Hurst for a nominal charge. Contact Tech Services for more information (818-483-1366, Monday through Friday, 9:30 to 5:00 PST)."
