If there was going to be a compression loss, the compression would follow the path of least resistance and zig zag through the gaps even if they were not aligned. It's simply an old wives tale. The gaps are under .030" of an inch. The piston only has to hold compression long enough for the spark to ignite the mixture. It would take longer for the compression to leak past a gap that small than the piston stays at TDC, so if there is a loss of compression to where the engine won't run, it's not because the rings are lined up. The service manual does show how to install rings. When they are installed new, none of the gaps are lined up. This is to assure that the rings and cylinders are broken in good and have plenty of time to seat properly. Since they do rotate in the bore, the gaps do line up from time to time. Once the rings are broken in, it makes no difference. Also, when the oil rings are assembled, there is NO gap. The oil ring butts against itself and creates a seal.
