daredevil
Having problems getting my 500 dialed in. Temp keeps climbing and i have to shut it down. Using a milodon mechanical pump a 7 blade fan and mopar thermostatic clutch. Also using a 16 lb cap on a aluminum champion radiator 2 core filled with 75% water 25% antifreeze with a bottle of red line water wetter. Can anyone tell me what kind of temp difference I should see on a 90 degree day between the inlet and outlet of the radiator. I,m thinking I can buy an infrared temp gun and shoot the top and bottom to find temp drop. I am wondering if the cheap Champion is doing its job. If theres not enough difference I may need to bite the bullet for a becool radiator. I,m also considering 36* timing total may not be enough but would like to narrow the possible causes one at a time. Started from scratch with whole car so cant undo changes one at a time. Plugs arent lean, maybe a little on the fat side so i,m leaning towards the radiator. Question, How much temp drop between top and bottom hoses on a well working system?
