valiant1966
I am building a 318 to replace my slant in my 66 Valiant. The engine is a 1970 with 77-86 heads casting #4027163. It will have a 4 barrel and cam with 421/444 lift. Bottom end is all stock. The heads are ported, polished and gasket matched.
My question is: How much can I mill off of these heads without getting into having to mill the intake sides of the heads. I am thinking that the factory gasket(steel) was about .020 thick and the gasket I am using(it came in the gasket set) is a Felpro 8553PT which will have a crush thickness of .039-.040 so I am sure I can mill .020 off but surely I can go a little more without having to make adjustments elsewhere. Thanks for any help.
