Someone know an easy way to install the coil spring on a 67 up style hood hinge? Or a ah **** spring.
Well thats is what i meant. Spiral springs then.?? Mine has the spiral springs...................
I did it years ago when replacing the stock springs with "lighter" ones for a Dart Lite hood. It probably involved big vice grips, big screwdrivers and a towel for some protection. But I don't recall any details.
Wouldn't that take all the fun out of it!????Why doesn't someone make a spring remover/installing tool like this? Just my silly idea. Stick this inside the coil spring and tighten the nuts, extending the spring. When installed, back off the nuts to remove.View attachment 1715709925
You could just get rid of the springs and use gas struts insteadSomeone know an easy way to install the coil spring on a 67 up style hood hinge? Or a ah **** spring.
Well hell i was hoping someone was going to come up with a do it this way , it’s simple. But I guess not eh?
