I have a centerforce DF clutch in my 67 Dart. How can I tell if the centerforce pressure plate is weak or not built correctly? Something has not been right since day 1.
Things I have checked are:
1. Clutch pedal has 5 1/4" pin spread
2. Pedal measures 7" from carpet to top of pedal pad.
3. 14 1/4" rod from pedal to Z bar.
4. Z bar is like the on in this link, Z-bar measurements please!
5. I have the 734 bellhousing with the correct ball stud bracket. Brewer's Performance - Mopar A833 4-Speed Transmission and Component Specialists
6. Z bar is level. So is adjuster rod going from Z bar to fork
7. Disc air gap is .035" with pedal on the floor and no slack between the throwout bearing and pressure plate.
8. If I keep adjusting the rod I can get more air gap. I got it up to .060" with the pedal on the floor. Of course I can't run it this way, just experimenting.
