Hydro boost system on lifted trucks and heavy tires?
Cope
Fusing with fire
San Jose, Ca.
Any one familiar with the hydroboost system please chime in here.
Is this system just not capable of pushing 37-12.5-16.5 tires?
I swear this is the second Hydro boost system that just won't push the tires.
What is the issue here?
I'm not sure i understand "pushing" big tires ?
That said, I had hydro boost standard on my Chevy dually. I hated it, I consider it a life-threatening failure possibility .
Still have them on both my diesel trucks. Still hate em.
My old 01 Dodge Cummins---which I converted to 4WD last fall--has the best (factory) brakes on any vehicle I've ever owned. It just flat STOPS. I'm not worried particularly about failure (engine failure) because it's a stick, so unless the engine locks up, I can motor the engine through the gearbox to keep the PS and hydroboost going.
Cope I know you are a smart guy---I hope you realize that the larger dia. the tires, the worse the brakes---because the bigger the tire, the more leverage they have against the brakes, therefore you need larger and larger brakes.
Yup, converted a hydroboost system onto the dart.
I don't understand pushing tires though because hydroboost is a braking system for engines that don't make enough vacuum.
Mustang has been using the system since mid 90s (that I am aware of) and every diesel truck has a hydroboost system. Also the old astro vans had them as well.
I love Hydroboost. I converted my ‘74 dodge 3/4 ton. It’ll put ya through the windshield if ya ain’t careful. lol.
