I have health news
Sorry to hear the news Cliff, hope they can find a way to make things better for you, they can do wonders with the heart and veins these days to improve blood flow. I will keep you in my prayers and do your best to listen to the docs
Freakin' cancer. Sometimes the "cure" is worse than the disease with the lingering affects.
Cliff, take care of yourself, bud. I'll be puttin' up some prayers for you.
Sorry to read/hear Cliff. Make sure you work like they say with swimming/sex "buddy system". Will help develop comraderie while having someone watch over you. All the best bud!
Prayers sent as always. I was just thinking and Idk if it would work since I'm only in two years for my degree but after you take your pills for a while I wonder if they couldn't use a stint to in large them a little? Just an idea I know its not the normal use but it may be a possibility. Keep strong man we are all pulling for you.
I am trying the drugs but this has been long term damage.
Dang cliff i want to come down there to see you but we over spent this month .
Asa don't worry about it.
Yeah Robert seems like chemo can do more damage than good in my case but I am still here fighting everyday.
I can't swim Steve so I might end up sinking like a rock LOL
Just now caught this thread. Is there anything they can do to correct this or is it something that you just have to live with?
Something I have to live with Bill
xs2 Cliff ?
i sent you an Email , hang in there bud and take it easy.
Thanks Lance I got your email.
Thank You all for the prayers it makes me feel better and to keep fighting.
Here is a description of what I'm talking about Idk ask your doc if its possible.
301.497.15908730 Cherry Lane - Suite 10, Laurel, MD 207078667 Georgia Avenue, Silver Spring, MD 209101310 Southern Avenue SE, Washington, DC 20032
HOME
ABOUT US
PROCEDURES
PATIENT INFORMATION
LOCATE OUR OFFICES
CONTACT US
Endovascular Procedures
Aortic and Thoracic Stent Grafting
In an endovascular stent-grafting procedure, a small metal cylinder called a stent is implanted in the artery to provide a strong new vessel wall. During the procedure, a thin tube called a catheter is guided up the aorta to the site of the aneurysm. A balloon on the end of the catheter helps fit the stent into place. Then the catheter is removed. The aneurysm generally shrinks around the stent as time passes.
Atherectomy
Atherectomy refers to a group of angioplasty procedures that remove plaque from the artery walls, and is most effective for blockages that cannot be easily treated with stents. During the procedure, a catheter with a sharp blade is inserted into the affected vessel to scrape off plaque and collect it in the tip so that it can be safely and thoroughly removed from the body. This process can be repeated multiple times during the same treatment to remove a significant amount of plaque.
Carotid Stenting
Carotid stenting involves the implantation of a metal mesh tube (a "stent") to hold a clogged artery open so blood can flow through it unobstructed. The stent is put in place using a technique called balloon angioplasty. A small tube known as a catheter with a tiny balloon on the end is inserted into an artery in the groin, snaked up to the carotid artery, and gently expanded, pushing open the blockage and restoring blood flow. The stent is then put in place to ensure that the artery stays open.
Endovascular DVT Treatment
Deep vein thrombosis is a serious condition that occurs when a blood clot, also known as a thrombus, forms in a vein deep within the body. Treatment for deep vein thrombosis aims to keep the blood clot from getting bigger, breaking loose, and causing a pulmonary embolism, as well as reducing the risk of developing another blood clot. Endovascular treatment can remove diseased veins, causing them to collapse and seal shut to relieve pain and other complications.
Endovascular Laser Treatment of Varicose Veins
Endovenous laser therapy (EVLT) is a minimally invasive procedure that treats varicose veins faster, safer and more effectively than other procedures, as it precisely targets the affected veins with a laser probe under ultrasound guidance. The laser energy delivered to the vein damages the vein walls and shrinks the vessel so that blood can no longer flow through and is diverted to healthy veins.
Mesenteric Artery Balloon Angioplasty and Stenting
Balloon angioplasty is a minimally invasive procedure commonly used to treat blockages within the mesenteric arteries. During this procedure, a long, thin tube called a catheter is inserted into the blocked artery to help expand it and allow sufficient blood and oxygen to reach the heart.
Balloon angioplasty sometimes includes the insertion of a stent during the same procedure. A stent is a mesh-like device used to keep passages open and improve blood flow. The stent may be placed over the balloon and then left behind to maintain the expanded artery.
Peripheral Vascular*Balloon*Angioplasty and Stenting
Angioplasty involves inserting a deflated balloon into the affected area and then slowly inflating it to push plaque to the side and widen the artery. A mesh tube called a stent may also be placed in the artery to hold it open after the procedure and reduce the risk of re-narrowing. This procedure is most effective in treating larger arteries or those with short narrowed areas, although other types of arteries can also be successfully treated with angioplasty.
pace yourself cliff and i hope they get your new meds right the first time.
That was one of the thoughts, but the damage is in the veins in the heart muscle itself.
Dang it! Well I'll ask my teacher he is a specialist in other docs have no idea problems lol. Really though he has shown me some amassing stuff. He uses both eastern and western methods. I helped fix my mothers migrains she had for 30 years so maybe my reasearching might find something they over looked. Ill try my best hate to hear this about you man.
Thanks
Cliff, just seeing this...Sorry to hear the results of your visit.
At least you know where the problem is now!
Prayers sent!
burg
Be well my friend. Seems like we never get good medical news as we age.
Prayers sent!
burg
Thanks Burg yeah and being extra careful isn't going to help :banghead:
Sorry to hear Cliff....it's good that now you know about this so you can take care of yourself accordingly.
Thanks David but my wife nailed me by saying I would work like I want to so now it has to be a new learning curve for me to take it slow and easy. If it seems I am saying this a lot,I am trying to reinforce it so I don't forget.
Sorry to hear about the heart trouble. Prayers sent, and try to just stay calm and see what can be done. Listen to your Docs and maybe just do things slower and with more breaks? Hang in there Cliff!
Thanks Harry I will be watched like a hawk and I am not able to start walking until next week.
