ID Help.... Clutch Pedal Identification
ToMang07
Maine
Does this look like a 67-69 clutch (A-Body) pedal assembly? Price is right and it looks to be in great shape to me! Just wanted to double-check before I send someone I've never met money.
Thanks!
Looks to me like the early version of the 67-76 pedal. Later (post 72????) Ones had the brake pedal arm turned 90 degrees where it was attached to the pedal as in the picture.
for sure 67-9 ....70 to 72 are the same set with exception of a neutral safety switch, so the ones with an NSS like yours are 67-9
