coffeedart67
I am getting ready to order new brake lines and I want to replace the lines that run between the wheel cylinders. How do I determine what size brakes I have. I have the front suspension with brakes at home but the car(with fender tag is about 30 miles away). It is a 67 Dart GT Convertible, 273 (2 barrel) automatic, and has drums all the way around. Also what wheelbase is my car so I am sure to get the right line from front to back?
Some more brake quesions. I took the fronts off and measured and they measure 10" across the inside, so 10" right? Are the hubs available anyplace as 2 studs on one hub and one on the other are welded to the hub. Did some checking and my car is 111" wheelbase, correct? On one drum there is a hole in the side, and the other there is a spot with wled on it in about the same location, what is this? My proportionaing valve has been off and open for about 2 years, should this be okay to use or should I replace it?
Thanks
Thanks
