needsaresto
- Joined
- Nov 13, 2004
- Messages
- 7,603
- Reaction score
- 265
There is a local guy who has a cobra /427 side oiler. He installed a centre force....it lasted 4 months LOL!!! Probably the way he drives it.
thanks for the question, Dan.
Yes, i am now happy with it, (now that it's broken in).
I resisted getting on it for 600 miles, and followed the break in procedure to the letter in the instructions.
Then i finally got on it last fall before i put the car away for winter, and it hooks and feels good!
I believe that it is a good clutch set up for a car under 500 H.P., and will last a fair amount of time at that power level.
It is as good as advertised.
Good and bad?
Well, i'll try to explain my experience to you.
First the good:
-Easy installation. No problems whatsoever.
I love the way it engages, it is mellow to drive with no finessing or special technique needed at all. I bet you couldn't stall the car unless you really tried.
-It really locks up when you get on it from say 4000 rpm and dump it. Smooth initially for a split second while the front end lifts slightly, and then boil the hides off. No slipping, and no smells of burning clutch material.
-It definitely isn't an ''on off switch'' type of clutch. Actually, it's quite the opposite.
Now the bad:
-It's tricky to get it adjusted just right.
My setup uses 100% stock linkage with a nearly new flywheel. Initially i had about 1/2'' of freeplay by hand at the top of the pedal. That was too much, as the clutch wouldn't disengage fully even with the pedal pushed all of the way to the floor. I ended up with about 1/4'' by hand and it JUST disengaged enough to fully release just before the pedal hit the floor. Now that i have some miles on it, you have to push the pedal almost to the floor to release it, (i would say about 3/4'' from the floor), which is about right.
-Removing the over center spring in the car is a pain in the ***.
I ended up using a cut off disc on a die grinder for this. I'm an old man and not a contortionist, and i cursed this part immensely!
-The pedal feel isn't as light as everyone claims it is.
I was told that it's lighter than stock, and that is B.S.
The original clutch i had in the car was a stock replacement Borg&Beck for a 340, and it
was lighter feeling than this one. Not a big deal, but worth mentioning......
A few more footnotes:
My (maybe) 300 horse 360 won't even phase the capabilities of this clutch set up. If i had a 600 horse setup, i would probably look into something different, but up to say 450 horses, i would definitely recommend this clutch to anyone.
The clutch works as advertised, and the car shifts well, so i feel that it is engaging and disengaging properly.
In the past i have used McCloud street and strip Borg&Beck clutches and they worked very well and took a lot of abuse without failing or any problems at all for that matter.
The pedal stiffness was slightly more with them than with this set up.
I run Pennzoil GL4 Syncromesh oil in the transmission, and it works very well.
The transmission is a '71 833 out of a 340 Duster that is all stock and in good shape.
I also would recommend the Dakota pilot bearing that installs in the crank register and remove the pilot bushing. Some people say don't do it, but, i have had zero problems with it.
The whole set up including all of the minor mods i made makes no unusual noises or vibrations associated with the clutch throwing off the balance of the engine etc.
Overall, i'm happy with it.
Thanks again,
Tom.
P.S.
We could exchange phone numbers and talk some more if you want........or you can come down here and try it out and see how you like driving it, and make your decision for yourself!![]()
Thanks for all the great info Tom, its been so long since I put my fresh 340 4speed set up in I can't remember for sure but I think it was a McCloud plate and disc set up and it performed well for me but if I was going to change my set up during this build would be the time to do it. Mostly I was looking for a little less pedal pressure since this 54 year old leg isn't what it was when I was in my 20's when I parked the car, lol!
Maybe will run into each other at some of the swaps or shows and I will contact you if Tom if I need some more info. You can tell by my build I'm a little way off the goal this year being to get the shell into paint before winter.
Thanks Tom
I'm 53, so the lighter pedal was a concern to me, especially since i've had my left knee scoped 2 times for damaged cartilage.
It is lighter than the McCloud set up from what i remember, i don't have one side to side to compare.
I think you would like it in your application............:cheers:
Yeah, we'll run across each other one of these days, i don't get up to your neck of the woods very often though.
Let me know if you need anything for your project Dan, i just might have it, you never know!
Tom.
Yup. Animal and that sideI got 150,000 miles on the stocker in my 94 chevy pickup. Owned it since new. Either this guy doesnt know how to drive a stick or he's an effin animal with it all the time. Some people just need 2 pedals, and a slushbox.
Glad to have helped you, to me, this is what build threads are all about.........I have been working on a 1974 Scamp for a friend, replacing the torsion bar cross member, torsion bars, brake lines and other rotted out floor sections. All that was left was the brake cable. The cable had been tie-wrapped to the torsion bar on one end the other dangling in mid-air.
It has been a long time since I had worked on this model but in the past had a 75 Duster as DD. Great car it was till rust did it in.
We looked thru FABO in search of the primary parking brake cable routing and mounting point. Happy to say that as a result of your build thread post # 17 we are now able to solve the mystery of where it is routed thru the cross member.
With any luck at all the car should be back running this week after 20 years stored in a garage.
Thanks for the info! James
And the black 318 4 door that i won my class bracket racing it in Spokane, Washington back in the late 80's!
Thanks for enjoying my build.????
I have lived in the Spokane area most of my life. Did you live here or travel to race?
BTW, love the build, just reading it after you linked to it in the "Stock or not" thread. Have to say, there is a whole lot of similarities between your car and mine. Some of the pictures gave me goosebumps thy were so similar to one's I took.
Back to reading.![]()
Thanks for posting the pics, DionR, very nice looking car you have there.Would be fun to meet up sometime. Hope is to have my car road trip worth before this summer, and if so, who knows the trouble I could get in.
Who did you hang with in Post Falls? Only name I can think of that direction is Mark T, but don't remember if he is in Post Falls or CD'A.
Do you ever remember an orange 340 Duster with strobe stripes and an Air Grabber hood and "Cargasm" for a license plate? That was my brother's. I got into Mopars because of him and that Duster. Went to shows with him when I was in H.S. and until the end of '87 when I joined the Navy. Should have been some overlap between us at some point.
Never made it to the "Finals" but I sure remember when they were going on.
If you aren't aware, the city took possession of SRP several years ago and (I think) put the owner in jail for tax evasion or something. Now it is Spokane County Raceway and has gone through several managers. I try and go once in a while, actually ran my Duster at the Friday Night Drags last year.
Here is a current picture before our local club show. No stripes, but some interesting similarities to yours.
And a dirty motor shot:
That's what it's all about.............Found the time slips by accident this weekend. Best run of the night was 14.844 @ 90.80. Not the best. The 2.71 rear gear really hurt me with the OD trans as I wasn't really getting into 3rd (1:1) until just before the line, and the syncro's are so worn it wouldn't shift at times. It was still fun though.
Lots of new goodies I see Dart Sports are too often looked past I find. Looks like everybody rather have a Duster and if like me your car will be called a Duster more than once. Although they are brothers.
