i did only use silcone on the ends where the cork goes, and i let it sit for 18 hours before firing the engine, i drove it around for about half hour and checked the ends and there was no leaks anywhere. The second time around i used a healthy bead of ultra black permatex front and back, used a line as big as my pinky finger front and back and put an extra dab of rtv in the corners.
Then i also used edelbrock gasgacinch on the heads after i cleaned them and then i used it on the head side of the gaskets and on the intake side of the gasket and i used the gasgacinch on the intake too, and i used all brand new bolts and torqued it to 30 ft lbs, no more studs to break, and i got both broken studs out with an easy out. I can tell you that my vaccum leak was the cause of all my problems, that vaccum leak was why i was fouling plugs and it is why i coul never get it tuned.
I set my initial timing at 16 degrees and my total timing at 34 degrees and i have an additional 10 degrees of timing at idle from my vaccum advance on manifold vaccum, so i have 26 degrees of timing at idle and it idles smooth as glass. And it runs so much better, crusing down the highway i can tell a tramendous difference in how smooth it cruises down the road. I can for sure say that vaccum leaks cause all hell to break loose and that it is impossible to tune an engine with a vaccum leak.
