1967formulaS
Well, I've been chasing an overheating issue for months now and after changing a never ending list of possible causes, I decided to pull the engine down and see what's going on inside.
Is this white build-up on the valves normal? I use 98 fuel.
I also found the block was full of crap in the water galleries that was getting trapped in my radiator.
I am also thinking another issue us that I'm using my early 383 heads on my 76 model 440 motorhome block. The head gasket doesn't match, blocking off the coolant ports on the heads.
Time to pull the motor down and get it chemically cleaned and crack tested, put the later model 440 heads on and make a new radiator. hopefully this will solve the issue.
