swingercanada
Active Member
i have a 1973 swinger , i have a chance to buy a 8 1/4 suregrip out of a 1977 r/t aspen...is it worth the swap? will it bolt in
FMJ body diffs are all the same width, 58.54" which is slightly narrower than the popular '65 thru '70 B body diff swap at 59.2".
Can"t vouch for the accuracy, but here's my sourceIn the interest of accuracy, I beg to differ.
First, I've measured my F-Body axle, and it measures 59.5" wide, from out of brake drum to out of brake drum. Perhaps you are listing the track width? If so, they are completely different, with track width being pretty much useless for information as I think it is influenced by the wheel and tire widths the factory supplied on the car. Drum to drum widths will allow you to at least compare widths from body to body.
Lastly, the B-Body axles in the years you mention are different in width with the 65-67 being slightly narrower than the 68-70 (59.5" vs. 60.125").
Not trying to bust your chops, but thought it best to make sure the info is accurate so nobody is mislead.
http://www.carnut.com/specs/frear.html
thanks for all the info
i lucked out and found an 8 1/4 sure grip out of and a body
