K/H Caliper Lines and Bracket Correct?
Creedmoor
Recovering Fordaholic
Zillah, WA
‘68 Barracuda. Converting to front discs. Hard to find a good picture of the line/bracket for the fluid supply to the caliper (service manual calls it a “jumper tube”). This is the left side caliper with the line and bracket mounted the only way that makes sense to me. Wanted to make sure before I install it onto the hub/disc assembly. Is it correct? First time dealing with this type of caliper so advice, experience and knowledge is greatly appreciated.
Thanks!
Yep, your good to go.
That picture is all correct with the hoses, and bracket.
All that you need now, is the rubber brake hose, itself.
Common item.
You have the "star" pattern hose bracket, so order up the rubber hose, for a 65-66 "A" body car with disc brakes.
I buy my stuff from Rock Auto, without any issues, all these years.
Jim V.
hemi71x
