K.H Spindles
67Signet
Smoke and chaos stunt coordinator
Surprise ,Az
Hello
I have decided to do the K.H upgrade but I need the correct spindles for my 67 Valiant and i heard that the 10 inch drum spindle works with the KH set up??
If you have them let me send you cash so I can get it done b4 it rains.
I also need the backing plates and lower control arms with good ball joints or I will rebuild lower control arms.. I need to do the HEI upgrade for my slant six 170
If you have any of these parts please pm me
thank you much
67Signet
Hello
Not even remotely close to each other. The 10" spindles are VERY different from the KH spindles.
Here's a pic of a KH spindle
X2......also the lower control arms are the same.....drum or disc. The lower ball joints for the drum system can be reused too if you drill out the mounting holes for the bigger disc brake bolts.
They make some aftermarket disc brake setups that use the 10 drum spindles however...
Thank you everyone for your reply
you have helped answer my question but now where do I find the spindles???
and how much would be a fair price.??
thank you for your time and attention..
