It isn't just a bolt, the KH part has a machined shoulder, more precise than a standard bolt.Is this is fixed Kelsey for A body just go get grade 8 7/16 fine bolts In the length you need
PM sentI have a single one I can sell you $7.50 plus shipping
I have seen them a little different over the years but all were grade 8 like yours or mine. Hemidart67 has one for me.I just installed a set on my car and was pretty sure they were originals and they were threaded the whole way…. The bolts for the knuckle to ball joint were originals too. maybe they weren’t….
‘completely different head than yours. Here they are before disassembly, cleaning, and the reinstalled with new calipers and hoses etc….
What are the dimensions of your bolt? I’m going to remove one of mine and ensure I at least have enough threaded portion (which I think I do - I had many many turns of engagement) but would like to know. Just learning mine aren’t original thanks to your post.I have seen them a little different over the years but all were grade 8 like yours or mine. Hemidart67 has one for me.
Dimensions are in my picture. It is off of a 67 barracuda Formula SWhat are the dimensions of your bolt? I’m going to remove one of mine and ensure I at least have enough threaded portion (which I think I do - I had many many turns of engagement) but would like to know. Just learning mine aren’t original thanks to your post.
Which ones and what do you need out of those? I’d need to have shipped to Alberta Can. You guys must have some sort of flat rate usps box or something to keep shipping cost down?i have some new kelsey hays brake caliper lines if any1 needs those
Thanks but im looking for the other ones.the medal lines that attach to 1 side of pistons to the other side caliper lines $13.00 no rust
I thank you so much. I know of inline Tube and other vendors That sell their stuff. BUT - guess how bad/much shipping for four little line like that is to Alberta. In-line wants $50. Mancini wants $33.
I believe I have those. Im in Vancouver.Which ones and what do you need out of those? I’d need to have shipped to Alberta Can. You guys must have some sort of flat rate usps box or something to keep shipping cost down?
thanks
you can PM the details if you like
Sure have a look And send me a PM. I can give you my email and phone number that way too.I believe I have those. Im in Vancouver.
