Key on power...
kc0r8y
Connecticut
Sorry for the n00b question, but searched and couldn't find a straight answer.
Where would be the best place to pull key on power for an electric fan relay on my 69 Dart? I'm using a Spal harness and Fan.
Thanks Ken
There is only one, known as "ignition run" or "IGN1" and is dark blue for many years........but not all. Comes out of the bulkhead connector, splits up at some point and feeds stuff like ignition system, voltage regulator, alternator field (70/ later) and some smog doo dads on some years. Electric choke if you had it, etc etc
You can download service manuals.........FREE for many years from MyMopar. Some of them there came from the efforts of guys on this board. There are also aftermarket, simplified wiring diagrams on the same site
Bear in mind anything in the fuse panel is "accessory" power. Scenario: You are working on the engine, and decide to listen to the radio. You turn the key to accessory, and while you goch'er hands in there, the temp moves enough to turn the fan relay on
Thanks for the insight!
CY21ftQxfo2leI6amBwMlWw5tPJ_V9PUXfMQnjen24ytEUde4VvUMgAY2ZJvn46ZCIqW2VSTrWUgiuH-B5G=w536-h714-no.jpg
