diymirage
HP@idle > hondaHP@redline
tried to drop the 360 in my duster today
with all the rocking back and forth the K member sliced through my milodon oil pan :banghead:
it is not oozing but it is bad enough that when you wipe it it will bleed through right away
its a cut less then an inch wide
is there any way to fix this?
im not sure if I can get a welded under there (im sure I couldn't weld it myself)
but I would hate to pull the motor again
any thoughts on J-B weld or yamabond?
