Hey guys haven't been on here in a while been super busy with work and stuff... First off i'm sure there is stuff on here about this currently but wasn't very successful finding anything lol. Anyways i was looking to build a 360 motor and install a set of magnum heads on it (heard that's the way to go for cheap build??) I know you need to get different push rods, lifters, cam etc. Main questions are is it worth it to get them? Do i need the magnum R/t heads or will a nice set from a junk yard work (obviously go threw them mangnaflux etc.) What is the selection of cams for this application? I will probably be running a nice set of light weight pistons get everything balanced will probably get a cam from .500 to .550 lift? My uncles helping a lot with the more specifics of the motor with all that but he builds 440s mainly and isn't too familiar with all the small block applications. Has anyone done the magnum conversion and do you think its worth doing or would standard LA heads be better? Sorry about the book i wrote haha just trying to get info on everything probably build it over the winter or so if everything goes as planned... Thanks for all the help guys!!
