Ladder bar - shock settings
moparstud440
Keymar, MD
On a ladder bar car with double adjustable shocks, how would you adjust the shocks so the car responds quicker? I've been running some index races on a Pro Tree and my lights are not as good as I want them to be. I have a pretty good setup for normal bracket racing so I'd like to be able to just make a shock setting change as it's quick and easy. My front shocks are only single adjustable, but I go from 2 clicks to 10 clicks for the Pro Tree. I could try tightening them up more, but was curious how/if I could change the rear shocks settings to make the car respond quicker.
I have a ladder car, but it is so messed up, I couldn't give any advice off my experience. I got away with it because of very light weight, and very large tires, . Couldn't tell you what shocks are on it.
I would recommend Kevin Wilson's you tube channel
Very in depth info on all kinds of rear suspensions ladders and shocks included.
Check out Kevin Wilson on YouTube the guy knows his *****.
