Lakewood Bellhousing big Block
bacaruda
WV
Big Block Lakewood 15330 bell for Mopar 3 and 4 speed, ALSO has been drilled and weldnuts added to fit TREMEC! It has been bolted to a block by previous owner, but has never been on a running engine, or installed in a vehicle. So it is functionally brand new. It has a small section trimed for header clearance.
10.5" and 11" Clutch.
Shipping charges are by your location. Unless you are local for pick-up. I can deliver up to 90 mi. from 25401, at $.55/mi., IRS standard rate.
It is 45lb.
$350 OMO
Thanks,
Jim.
