Rapid Robert Well-Known Member Joined Aug 6, 2006 Messages 1,936 Reaction score 478 Location Lincoln Nebraska Apr 12, 2024 #1 the round nub at the top of the leaf spring center bolt is just tall enough to fit the thickness of the perch. If I add a shim the perch will not be engaged. How do I get around this? thank you for your time. RR
Oldmanmopar Going left turning right FABO Gold Member Joined Jan 8, 2009 Messages 13,414 Reaction score 13,129 Location Danielsville Pa. 18038 Apr 13, 2024 #2 Replace the center pin with a taller one from a local spring shop.
str12-340 FABO Gold Member FABO Gold Member Joined Dec 26, 2012 Messages 4,375 Reaction score 4,022 Location Vashon, WA Apr 13, 2024 #3 clamp the spring leafs securely before you replace that bugger!!! ESPO has longer nub bolts if you can't find then locally.
Rapid Robert Well-Known Member Joined Aug 6, 2006 Messages 1,936 Reaction score 478 Location Lincoln Nebraska Apr 13, 2024 #4 got it, thanks guys I will find a longer one & clamp the springs in 2 places before I unbolt. RR
