bozvaliant
Hi,
Just got my 360 Magnum in my Dart running today!!! Found a small water leak coming from around one of my freeze plugs.:banghead: It's very small, should I put some aluminum sealer into the cooling system, or bite the bullet and change the plug. The engine is from Mabbco motors. They supplied my short block. The other leak is coming from the timing cover where it meets the oil pan. It's a Felpro one piece oil pan gasket, and for some reason there seems to be a space where the timing cover meets the oil pan. Should I drop the pan down and add rtv?:violent1:
Thanks
Thanks
