Leaky 727
Discussion in 'Transmission and Drivetrain Tech' started by Gandy Dancer, Jan 12, 2018.
  1. Gandy Dancer
    Gandy Dancer Well-Known Member
    75
    1
    Jul 9, 2010
    Lanham MD
    View My Photos
    Local Time:
    7:25 AM
    Hello FABO - I have installed a rebuilt 727 in my 66 Barracuda. Mounted to a 318. When I removed my 904 it never had any issues with leaking at the dipstick tube. I am now having leaks occur at the dipstick and I cannot seem to prevent the leaks. I've tried RTV red, and it did not work.
    Does anyone have any recommendations or ideas on how I can prevent a leak at the dipstick. And unfortunately like the 904 there is no bolt hold to fasten the dipstick to the transmission.
    Thanks!!
  2. Plymouth 65
    Plymouth 65 Floorable Deplorable
    250
    113
    Jun 27, 2016
    Mich
    Local Time:
    7:25 AM
    Did you use a new o-ring also? 65'
  3. joshcook81
    joshcook81 Well-Known Member
    92
    16
    Oct 29, 2015
    Georgetown
    Local Time:
    6:25 AM
    My 727 dipstick tubed leaked, I pulled it out and changed the O-Ring, hasn’t leaked since :)
  4. 70Duster440
    70Duster440 Well-Known Member
    2,531
    125
    Jan 8, 2006
    Washington
    View My Photos
    Local Time:
    4:25 AM
    As mentioned: fresh o-ring. Be sure to clean all the RTV off and don't use it. Then figure out a way to secure to tube so it doesn't flop around.
  5. 1994redram
    1994redram FABO Gold Member FABO Gold Member
    445
    60
    May 9, 2012
    Oklahoma
    Local Time:
    6:25 AM
    I always clean it up really well and put A fresh O-ring on it with a thin coating of RTV. Always worked great for me. The dipstick tube has to have a way to bolt it on. Without it bolted up and mounted correctly, the fluid readings will be off. The dipstick tube will sit too low into the trans.
  6. forphorty
    forphorty Well-Known Member
    496
    104
    Jan 19, 2006
    Local Time:
    6:25 AM
  7. iScamp
    iScamp Well-Known Member
    73
    39
    Nov 1, 2012
    North Carolina
    Local Time:
    7:25 AM
    I might be missing something here in the conversation but.... you're saying there is no tab spot welded to the dipstick tube? That tab would be secured to one of the bellhousing bolts. (in most instances)
  8. Demonic
    Demonic Well-Known Member
    130
    38
    Mar 21, 2015
    Maryland
    Local Time:
    7:25 AM
    Also, make sure you have the correct o ring. Too thick and you'll never get it seated, too thin and it will leak again.
  9. 70Duster440
    2,531
    125
    Jan 8, 2006
    Washington
    View My Photos
    Local Time:
    4:25 AM
  10. Gandy Dancer
    75
    1
    Jul 9, 2010
    Lanham MD
    View My Photos
    Local Time:
    7:25 AM
    Excellent! I will take these recommendations and revisit my dipstick. I may start fresh with the Mancini dipstick. That looks rather promising.
    Thanks!
  11. d55dave
    d55dave Well-Known Member
    1,872
    429
    May 20, 2010
    Kelowna, British Columbia
    Local Time:
    6:25 AM
    Somewhere around 66 and earlier 727s have a 90 degree tab welded to the bottom of the tube that bolts to a tapped hole on the trans housing adjacent to where the tube goes in. They also have a tab that bolts to one of the bellhousing bolts. 67 (I think) and later only have the tab for the bellhousing bolt.
    Regardless, it is important to pre fit the tube and ensure that, when the tab(s) are bolted up, the bottom of the tube isnt pre loaded. Once you have determined this, use a new o ring, wipe everything down good with lacquer thinner or brake clean (including the ID of the trans case that the tube fits into), use a reasonable (not excessive) amount of good sealant such as oil resistant rtv under and on the o ring, insert the tube and tighten the mounts. Let the sealant cure before adding oil.
    This is usually something that I do as a last step, once the trans is in, the mount is on and everything is tight, to avoid tweaking the tube. I also use my finger and put a bead of sealant around the tube to trans case interface.
