My 8 3/4 leaks down the back of the housing when I drive it... ALOT !
At first I thought it was the gasket I used ( trying to do it the correct way...) so I pulled the
pumpkin and used silicon.... still leaks ! Thing is that its not dripping from the gasket joint...
but down the back of the housing...seems to be originating from the top of housing where the back plate is welded on.... or where the brake line stay is tacked on.
I cant feel or see any hole or crack....even took pics of the top of housing .
I replaced the NEW vent tube vavle with an old loosy goosy one to make sure pressure wasnt building....still leaks !
