Yes it would be the same! You have one available?thxWould a 68 barracuda be the same maybe?
I took a couple of pictures of the two rot spots I have on the pass side rocker panel. One is in the front behind where the front fender would come down and cover. Second is behind the front part of the quarter panel. So I didnt see this rot until I cut the quarter off. Just need a piece on both front and back. I'll send picturesWhen u get a chance stick your fingers on the top of the frame rail by where the shock tower meets the frame. Mine rotted out there
Ok let me get it all cut off and I'll let you know. It'll be a couple days
Sounds good thanksI always bring a good supply of A body frame rails to Carlisle. Should have plenty to choose from if you don't find one.
