Light Weight Wheels
SRT_DSTRHOLC
USA
Who is running light Weight Drag or Street wheels? Im looking to get some. Pictures always wanted
Not yet as my Dart is still in 'build mode', but I've got these Centerline's to run on it. Rotary-forged, 30% lighter than cast wheels. Really impressed with how light they are.
I plan on running these Centerlines. According to their website they weigh 16 pounds and are "are approx 30% lighter than conventional casting".
That sounds about right. Mine are still in the boxes out in the garage.
I picked these up from ebag new for cheap because of the shallow offset. Now if I could just find the matching front skinnies. They are 15x12 American Racing Trakstars and they are getting hard to find.
Holeshot has a wide variety of styles and offset. They are a "drag only" wheel, but some people have cautiously run them on the street. In some cases, a thicker center and/or rim halves can be special ordered. They have even lighter 1-piece fronts but they are more expensive.
http://www.holeshotwheels.com/
website says the Centerline pro stars? are about 12-13 pounds for 15x8 15x10 i think are 14-15 pounds
15x3.5" Bogart drag-on fly star
9 lbs
15x7.5" Bogart Classic Star
10.5 lbs
15x8" Bogart Classic Star
11 lbs
15x3.5" Weld draglites
10 lbs
15x8" Weld draglites
13 lbs
15x10" Weld draglites
14 lbs
15x8" Weld Rodlites
13 lbs
15x3.5" Weld pro-stars
10 lbs
15x8" Weld pro-stars
12 lbs
15x10" Weld pro-stars
14 lbs
15x4" Centerline Convo-Pro
9.5 lbs
15x8.5" Centerline Convo-Pro
12.5 lbs
15x4" Centerline Tel-Stars
12 lbs
15x8" Centerline Tel-Stars
16 lbs
I have a set of weld pro-stars on my cuda and I would actually like to sell them. The rears were used on my amx for 3 years then I took them and put them in the basement for the last several years. The fronts I bought off a local racer on craigslist.
5 on 4 1/2 bolt pattern
Rears are 15x8 with 5 1/2 offset
fronts are 15x4
If your interested let me know [email protected]
As a side note these wheels will clear front '73 and later factory disc brakes and rear late model jeep cherokee rear disc brakes. That wasn't the case on my amx which has wilwoods...ended up buying centerline wheels.
Yes I might be interested, but with that much backspacing I might be able to fit 10s as you did 8s on your dart.
