73Scamp318
I have a like-new Edelbrock EPS 800 manual choke carb (PN 1412) that the PO of my car used for engine break-in. It doesn't look like it's been apart and should be in good working order. I need to get some cash scraped together to purchase my wedding band for my upcoming hitching in August.
Here's the info from Edelbrock's site:
EDELBROCK EPS 800, MANUAL OR ELECTRIC CHOKE CARBURETORS
CALIBRATED FOR PERFORMANCE
Designed and calibrated for maximum street performance with most Performer RPM, RPM Air-Gap and Torker II manifolds and with Performer manifolds on large cubic-inch engines. Dyno tests proved that the EPS 800 carb outperformed a Holley #3310 carb out-of-the-box by 26 ft/lbs. of torque and 22 hp on a small-block Chevy engine equipped with an Edelbrock Performer RPM power package. Features include a high capacity accelerator pump and an improved primary and secondary cluster design. EPS 800 has the same superior features as the rest of the Performer Series line such as out-of-the-box performance and 2-piece design. Comes with: Metering Jets - Primary .113, Secondary .101; Metering Rods -.071 x .047; Step-Up Spring - orange (5" Hg).
This carb sells for around $320 new from Summit and Jeg's, I'm looking for $250 shipped to the lower 48. Spacer not included.
http://www.summitracing.com/parts/EDL-1412/
http://www.edelbrock.com/automotive_new/mc/carbs_acc/performer.shtml
