Holley's own (damn poor) site suggested it was 15 psi. This was their online catalog, what a POS.
https://www.holley.com/12-927.asp
Summit says 43 gph, 15 psi
http://www.summitracing.com/parts/HLY-12-927/
Well hell, if Holley won't publish actual figures on their own pumps, how the heck are you supposed to TEST them?
OK but the question remains, if the Holley specs are not "real" then how do I know how much pressure I need? I do understand this is regulated in the TBI, but no idea what it's limits are.
All I can go by is the published Holley specs, and you guys are saying "that's low."
In my limited research, it looks like some that are using a higher pressure pump are also using a vacuum referenced regulator to keep from being dead rich at idle. Just put that out for info/disscusion.
Is this the 670 Avenger TBI? I found a Holley owners manual in pdf. Although i have no idea what good it would do.....lol.
Welp. Search is already over. Bought a Holley 12-927, the recommended pump off eFray fer 95 bucks, new. Jegs, Summit wants 152, so that's a sizeable savings
Yup. same pump. First thing I'm gonna do when I get it is find out how much it will put out!!!
