famous bob
mopar misfit
put a new gas tank-lines-return lines for fuel inj. new dual feeds out the back bottom of tank, fuel pump is very low on rear of car. put gas in it for the first time yesterday(4 yr. build) filled up and topped off at 7 gallons, think it`s an 18 gal. tank. no internal baffels, vent hooked up to top of filler tube(stock location), everything new or cleaned-not stopped up. thot the nose down attitude might have it air locked, jacked the front up level, gas did not go down in filler tube. went to eat about 2.30, came back in the garage-gas was running over, down the fender. 'HEAT EXPANSION" dam cheap 91 octane alcohol ate the single stage paint off the fender. siphoned about 1 1/2 gall. out to stop it. I remember back when I bought a new 68 barracuda when I was kid(first new car) it had some fuel filling issues, but not like this. what`s it going to take to make this thing work right? thinking maybe a vent added to top side area of the tank to let air out, hooked back into the stock vent tube that is behind the flip top cap, and drilling the top of cap w/ a small air bleed. any body out there got any ideas, of ben thru this, and how did you solve it?
I`m really pissded about this! tanks for any ideas or help-----bob:banghead::banghead::banghead:
