Lower front end...
Sublime69
Chicago
Ok, so i have stock front suspension and i have the torsion bars cranked pretty much all the way down... I want to lower the front about another inch. Is my only option to pull the trigger on some drop spindles? If so, what are my options on them? What do you have and do you like them?
Thanks!
So is magnumforce the best way to go? and will all my brakes bolt right back up with no change to the offset of my wheels??
PST also sells them and stock brakes will bolt no problem.
