Cope
Fusing with fire
Cut the extra pully off.
Less rotating mass and never gonna run power steering.
This Thread makes me want a machine shop! I would probably hand make 90% of the stuff how my car if I could. If you're running a mechanical water pump and you have a triangulated fan belt you might be okay. My problem was using that stock pulley and running the alternator way too fast when I'm rubbing her up past 5 and 6k. I only have the alternator that I run so my belt is not triangulated. With that big pulley and that little pulley it was throwing the belt no matter how well I had them lined up. And no matter how tired I had it once I got past six grand... fling!....
I ended up doing what I hate doing buying something instead of being able to make something. I bought a March performance reduced size pulley and it stop the belt from throwing off.
