connerray
I have some magnum heads I need to sell to fund a big block, there off of a 318 put from my research, there the same for 360 or 318. I'm not sure if there are any cracks, again from research cracks don't effect performance so long as its not cracked to the water jacket which I'm sure its not cause the motor was pulled from a running 96 dodge ram
Lifters, push rods, rockers, springs and valves go with them as well
I would like 150+ ship.
I don't want to check for cracks unless you are really interested as the motor has brand new head gaskets on it and if these don't sell, I will most likely stick with the 318.
[/IMG]
