[SOLD] March Aluminum Pulleys, SB
71Scamper
Mopar runs thru my veins!
Kingston, NH
Aluminum crank and waterpump double row pulleys. Also, a chrome double row alternator pulley with nut to compete the setup. This setup is for a small block with a long nose water pump and will not work with power steering. The alternator pulley will work with GM CS style alternators. Can be used with chrysler alternators if you use a .250 spacer. I don't have the spacer. I'll take $150 plus shipping
Will the water pump pulley work with a factory small block water pump? I am not sure what the long nose pump is?
if your water pump has it's inlet on the passenger side and is aluminum then you have the long nose pump.
