gunmetal72 Life is a dark ride Joined Jan 5, 2010 Messages 550 Reaction score 53 Location Sicamous B.C Jan 12, 2010 #1 Can someone tell me where I would look to find the numbers on the 340 engine, 4 spd trans & rear end so I can match them to the VIN #
MVRCorp Well-Known Member Joined Nov 10, 2006 Messages 1,723 Reaction score 22 Jan 12, 2010 #2 What year?
3 340butterduster no title Joined Jun 24, 2007 Messages 1,768 Reaction score 11 Location Ont. Jan 12, 2010 #3 The VIN have only been stamped from '68 on. The stamping VIN on the block and 4 speed trans. are on the passenger side. Block = at rear, on pad, just over oil pan. Trans (4 speed) = at front, raised block, just over the casting #'s.http://s203.photobucket.com/albums/...ion rebuild/?action=view¤t=IMG_1277.jpg I don't know for auto trans. Only the last eight digits are stamped. Which is model year, ***'y plant and serial number. Good luck!
gunmetal72 Life is a dark ride Joined Jan 5, 2010 Messages 550 Reaction score 53 Location Sicamous B.C Jan 12, 2010 #4 Thanks, I will take a look. Do you know where the #'s are on the rear end?
chasduster Well-Known Member Joined Sep 17, 2008 Messages 2,172 Reaction score 34 Location California Jan 12, 2010 #5 auto 727 vins are on the right front side of trans case......
Alaskan_TA Well-Known Member Joined Nov 12, 2004 Messages 6,415 Reaction score 5,289 Location PA Jan 12, 2010 #6 The VIN on an automatic is on the passenger side bellhousing. No VIN on the rear end.
