Black 69 Dart
Where are you guys hooking up mechanical oil gage to? On a 61 hemi.
I run remote oil lines - The jeep alternator clears the T piece no problem....dunno if a car one will... http://s467.photobucket.com/user/Th...mi Years/20121228_160003_zps92d5a257.jpg.html
I noticed in the front of the water pump there is a plug thinking of putting h2o mech gage there. I am also removing the pipes that come out of back of water pump that go the the heater tapping them so I could run gage off on of those.
Yea my water pump housing has that plug, it's too small for your standard mech temp probe. Which I believe is 3/8. Was thinking of tapping it a thread size bigger or possibly drill and tap opposite side of stock gauge for temp, I have gauge setup there, and I need to drill for electric fans relay.
Here's a write up someone did.
http://www.hotwireauto.com/?page=hemi_eng_temp
same block isn't it?I want to see pics of a 61 hemi !!!!!!!:wack:
Not sure - but its the same as an LA small block oil switch thread....
What is the thread size of the little oil passage on the block behind alt??
