There has been some interest in this system that I run on my 360 powered wrangler. I figure I would post what it is and how it has worked for me. Please feel free to ask any questions you may have about this setup. I should be able to answer just about any.
This system is 100% tunable. You hook up a laptop and set your fuel maps, air/fuel maps, can control timing, use a wide band O2 to control fueling, boost control, launch control, nitrous control, etc...... The software is open source, meaning anyone who has programing now how can have it do what they want. There really is no limitation!
Nice feature is the ability to data log. Go drive around and capture the data. You are able to monitor any sensor to check for faults and to just see what your engine is doing. If it’s running rich you will see where and why and are able to make changes.
Typical data log:
I first started out using a chevy 350 TBI on an Edelbrock dual plane intake. It was OK, but could never get it to run great. After a few years I decided it was time to go true EFI and purchased http://www.summitracing.com/parts/edl-28155/overview/make/chrysler.
Freshly powdercoated intake elbow and rails:
One coated rail vs. natural aluminum that has been bead blasted:
I plugged the injector holes and slapped the TBI back on as I had an off-road trip to attend and didn't have time to complete the EFI swap. WOW, the difference from dual to single plane was HUGE!!! Much better response and power.
Once home I pulled the TBI and put the 8 injectors in. It does cost more money to go with a true EFI setup, but I would not waste my time with a TBI if you are not running a stock engine.
My setup: (Sorry dirty pic is all I have)
I run 2006 Ford 5.4 injectors
Ford Econoline inline fuel pump
Aeromotive FPR set to 45 Psi
Throttle body is from a Ford 5.0
www.diyautotune.com is where I purchased my ECU. You can buy the kit and solder it all yourself. I went this route......and boy was it a pain! If you have the money, just buy it built.
When i first went out my engine would cut in and out every so often. I dataloged a drive and played it back. I could see the reason it was cutting out was because I was loosing the signal from the tach. RPM would drop to 0, which would show the engine is off and fuel would stop being injected. Found out a jumper wire in the computer was installed for the wrong type of ignition pickup. After 10 mins, it was fixed!
Wiring is not hard. But the harness pigtail and just it to each sensor. The wires are labeled very nicely so you can't screw it up. Make sure you ground the sensors correctly or you will have noise!
What else would you all want to know???? I feel I am rambling.......
Typical data log:
