Here is a list of parts, prices and where purchased for fuel injection conversion for my hemi engine. If anyone is still interested.
computer: Megasquirt III V3.57 $550.00
there are less expensive computers ava.
wiring harness 12' $85.00
2 gm closed element clt/iat sensors $16.00 ea.
Innovate LC-1 wideband controller
w/o2 sensor $200.00
The above were purchased at (diyautotune)
Throttle body: fast throttle body $614.00
(diyautotune) has the same one for $529.00
and there is cheaper throttle bodies out there but the radius
on the inlet side looked to be a smoother transition than the
cheaper ones.
Regulator: Aeromotive #13101 for EFI $160.00
Fuel filter: summit racing #230118 (i already had this) $70.00
These were purchased at (summitracing)
Fuel injectors: 48lb/hr injectors & pigtails $500.00
Fuel pump: bosch 044 external pump $189.00
These were purchased at (fuelinjectorconnection)
you could also try (southbayfuelinjectors)
I bought 3' of fuel rail blank for $11.00 per ft. Nobody made fuel rails for a hemi. there was also $200.00 or so in AN fittings and hose.
I also had to fabricate my own brackets for mounting regulator,pump and filter and throttle cable. I also have friend who machined my intake and fuel rails.
I hope that this is helpfull to anybody that is interested in going to EFI.
w/o2 sensor $200.00
cheaper ones.
