boosted
Life Needs Air
Hood hinges... Spring towards fender or body? I just need to figure out left and right...I have a 1967 Barracuda...
"I so wish" we had the same deal as B bodies.................
I drilled a cotter pin hole in each stud and use a spacer between it and the hinge. Allows me to push the hinge arm closer to the body and seems to to eliminate that outward flex being tighter.I dont like the cheesy spring clips/washers that half them on. Cant see why a threaded stud/nut wouldnt have worked?
Also a "fair bit" of outward flex when closing hood.
Early A tortion bar..... Talk about not attractive.agree, sorriest hood spring set up I ever messed with
