howiedodat
Active Member
Here is a Barry Grant Mighty Demon 750 vacuum secondary annular discharge carb. Just off of my 1968 Satellite. The carb is about a year old and just off my car. I have included a photo of it on the motor. I bought it new. Included is the dual feed line, the manual and a Russel fuel pressure guage. The carb alone is $600 new. Excellent used condition. I switched to dual Edelbrock carbs. Here is a little info on the carb. More info is available from the Barry Grant web site.
750 Annular Speed & mighty Demon Features:
$425 SHIPPED INSURED UPS TO THE LOWER 48 STATES.
I CAN ACCEPT CREDIT CARDS THRU PAY PAL.
- Patented air entry design and concentric venturii -promote fine atomization and consistent cylinder filling
- Billet baseplate and metering blocks-provide a solid, non-porous, trouble-free material that guarantees reliability
- Patented sight windows in fuel bowls-ensure safe and easy float level checking
- Adjustable four-corner idle, primary and secondary jets-offer precise idle tuning which promotes better distribution
- Integral fail-safe power valve-prevents rupture during back-fire
- Dual inlet ports-allows independent bowl filling
- Vacuum ports: 2 constant and 1 ported-activates power brakes, distributor, PCV, transmission and other vacuum-operated accessories
