nitrohemi
Milidon dual pickup external oil system. includes the plate thea goes between the oil pump and block, plate that goes on top of the oil pump for the filter, swinging oil pan pickup, hoses and caps incase you only use one pick up, and longer distributer drive shaft for a 383/400 block. You just need the oil pump. $300.00 plus the ride.
