Mini Starter on 383 68 Cuda
340mouse
Oakwood Ontario
Anybody have pics of the nippondenso mini starter on there 383 Cuda.
I just bought a nippo 17466 and it does not look like it has correct orientation
or clocking.
Thanks Dave
From what I take on this, is that the connections are on top of the starter,
it just didn't look right to me.
Dave
Here's mine on a 400 block. You need to remove the plastic adapter, and I shortened the stud by a couple of threads as it was pretty close to the block.
same thing here Dave. After I installed it, put silicone over the connection to make me feel better as it was so close. Andrew
On my 400, I ground on the block a bit to clear the starter body. If you look at qkcuda's third pic, you can see how close it is.
