[FOR SALE] Misc. Drivetrain parts
RockinRobin
Corsicana, Tx
Rating - 0%
0   0   0
1. 8 3/4" sure grip differential. I removed it to install a spool instead of a differential. Notice that this is the Diff. only, no ring/pinion or front cover. $150 plus shipping or best offer.
2. Axles from same 8 3/4" rear end. 31 spline. One has a slight twist in it. Standard Mopar large bolt pattern. $50 plus shipping or best offer.
3. A-Body driveshaft with differential yoke, front U joint and transmission yoke. $50 plus shipping or best offer.
4. Transmission sheild for 727 torqueflite. Aluminum. Meets SFI 4.1 specs. $50 plus shipping or best offer.
5. Weld Draglite 15" wheels. WHEELS ONLY, NO TIRES! 15" x 10". 5.5" backspacing. 5 x 5" bolt pattern for 1/2" lugs. Pre drilled holes for bead lock screws. Mounted on car once but never used (wrong backspacing for my car). $300 plus shipping or best offer.
SOLD-1. 8 3/4" sure grip differential. I removed it to install a spool instead of a differential. Notice that this is the Diff. only, no ring/pinion or front cover. $150 plus shipping or best offer.
5. Weld Draglite 15" wheels. WHEELS ONLY, NO TIRES! 15" x 10". 5.5" backspacing. 5 x 5" bolt pattern for 1/2" lugs. Pre drilled holes for bead lock screws. Mounted on car once but never used (wrong backspacing for my car). $300 plus shipping or best offer.[/QUOTE]
Is the driveshaft from a Dart or Duster? Is it for a 727?
If the driveshaft came from a car with 727 and 8.75 I will take it how much to ship to 44312
SOLD-3. A-Body driveshaft with differential yoke, front U joint and transmission yoke. $50 plus shipping or best offer.
Differential and driveshaft are SOLD.
SOLD-5. Weld Draglite 15" wheels. WHEELS ONLY, NO TIRES! 15" x 10". 5.5" backspacing. 5 x 5" bolt pattern for 1/2" lugs. Pre drilled holes for bead lock screws. Mounted on car once but never used (wrong backspacing for my car). $300 plus shipping or best offer.
All that's left are the axles and the tranny shield.
