[FOR SALE] Misc used parts
75 Duster 360
High Point NC
One fuel pump block off plate, one 7 1/4 rear end gasket, one new oil slinger, 904 front seal, 5' aluminum fuel line 3/8", 3' negative battery cable, 3 A body window cranks, twenty 7/16" chrome lug nuts, two automatic shift levers, one outside rearview mirror, one gas cap, 4 barrel to 2 barrel carburetor adapter, 1967-72 A body upper control arm, used SB water pump, 16 hydraulic pushrods LA, two camshaft bolts + washers, oil slinger used, two oiling tabs, new SA Gear double row timing set, 4 used small universal joints, two used rocker shafts and arms, '67 J-bolt for gas tank strap, a low oil pressure cut off switch setup. All for $50 plus shipping from zip code 33570.
