[FOR SALE] Miscellaneous Performance Parts
earlymopar
Oregon
- (SOLD) New K&N #66-1401 High Flow Filter = $40 ($75 @ Summit)
- New Hamburger’s 1” Spacer #3201 $50 (sells for $100 @ Summit)
- Used Carburetor Spacer with Insulator = $15 / New FBO.COM electronic Regulator (SOLD) (replaces stock but made to look original). Was mounted but not used = $20 (sells for $28 @ FBO)
- Used Factory 90-Degree Oil Filter Adapter and Bolt (S/B) = $60 / New Summit E-Core Coil (SOLD), 40,000 V, #850500 = $25 (sells for $38 @ Summit)
- (SOLD) Used S/B Billet Pulley Set (could stand re-polish or bead-blast) = $65 (sells for $280 @ Summit) / New Melling Big Block Oil Pump Kit #MEL-K-63 = $30 (Sells for $53 @ Summit)
- ARP Big Block Cam Bolt Kit # 144-1001 = $4 ($6 @ Summit) / New Big Block Oil Pump Pickup Tube = $24 ($38 @ Summit) / New LA Rear Sump Pickup Tube (SOLD) = $18 ($30 @ Summit)
- Chrysler #1851658 Big Block Filter = $30 ($48 on-line)
- New Moroso #41200 Transmission Cooler = $75 ($120 @ Summit) / Used B&M #10231 Flex Plate (SOLD) = $40 ($137 @ Summit)
- New Comp Cams # 7957-16 Push Rods, 7.5” Length / 5/16” Diameter = $100 ($174 @ Summit)
All parts located in Newberg, Oregon.
