Modded 360: Not sure of Sparkplug Heat Range
QuickDart360
San Antonio
Ok guys and gals! My 360 is beefed up some with 340 X-heads, 292 mopar purple cam ( advanced 4°). KB107 flat top pistons not of actual compression, Victor 340 intake. 727 trans with an FTI 9.5" 3400-3600 stall converter. 3.91's out back. So my old set up was a 280 mopar cam and 3.55s then. That set I ran rn12yc plugs and did good. With this new set up do I go one step colder (rn11yc's)? Or stick with the rn12's? Please fill me in!
Stick with the RN12. you won't know the proper heat range until you read the plugs after running the engine.
